ONEX #54 Web Site
Date:  8-17-2013
Manual Reference:  E01
Brief Description:  Transponder tray
Decided to install the transponder and radio on the right side below the instrument panel.
To fit the transponder vertically, I needed to move the right rudder pulley down about 1". The cable needs to be in the same place to clear the main spar. I moved the upper pulley hole to the lower existing hole and drilled an additional lower hole. The pulley was mover to the top of the bracket and a cable retainer added.
Made some brackets for the transponder tray.
RH rudder pulley bracket moved down
Transponder and radio location
